    Nov 2012
    Default steam radiator cold
    on my upstairs radiator ( a one-pipe steam system), the riser pipe leading to this radiaor will get hot to the touch, as well as the floor valve that then connects to the problem radiator.
    The radiator remains cold. Does the valve need to be replaced?
    Could it be clogged?
    South*East
    1,213
    Default Re: steam radiator cold
    Sounds like a valve problem or a bad steam vent.
    John
    Nov 2009
    71
    Remove the steam vent valve on the radiator. If the unit starts getting hot, then replace that piece. BE CAREFUL though. That steam can cause a nasty BURN.
    If it does not get hot, check and make sure the inlet valve is open.
