    9
    Default gas water heater tank
    Hi,
    is there a way to test a gas water heater tank before I replace it with a new one?
    563
    Default Re: gas water heater tank
    What's it doing now that makes you think it needs replacement??
    9
    Hot water is quickly out. I think inside water pipe maybe broken off.
    563
    This could be something as simple as a detached dip tube inside the tank---check the other poster in the heating or plumbing section for a similar problem.
    Do you want to attempt the repair yourself, or call a service person???
    Click onto "Not enough hot water" at the site below.
    http://www.waterheaterrescue.com
