    Nov 2012
    5
    Question hip-roof attic insulation
    Hi. I'm new to forum and to DIY. Really could use some help.
    Need to reinsulate attic (approx 625 s.f.) in brick home built around 1950, no insulation currently.
    Pyramidal hip-roof with low slope rests right on the top of the house (facia lines up with roof edge and outside walls of house),and there aren't any soffit vents nor space for vents. There are two small box vents in roof.
    It also appears that there is a gap between brick siding and house walls,; gap runs perimeter of attic. Difficult to tell how deep gap is, perhaps the height of house.
    1-Could the gap be where insulation should be between drywall and brick exterior?
    2-Can I use blow-in fiberglass insulation and go all the way to the gaps? Or should I block the insulation from getting into the gaps?
    3-Do I need a vapor barrier before blowing insulation in (live in NJ).
    4- Can insulation come in contact with electrical junction boxes/armored cables that provide electricity for 2nd floor ceiling fixtures and outlets?
    Any help would be appreciated.
    Nov 2012
    5
    Default Re: hip-roof attic insulation
    Can anyone provide advice?
    3,179
    Are your exterior walls true brick ( a few bricks thick) or brick veneer (one brick thick) ?
    Nov 2012
    5
    Walls are about 8-9 inches thick; I had taken down some drywall in the kitchen and it was attached with furring strips to the inner part of the wall consisting of cinderblocks and brick; e.g. row of cinderblocks, 2 rows of brick, 2 rows of cinderblock... The outer (exterior) part of the wall is brick. I assume all walls are therefore two layers of cinderblock/brick and brick only. Would this be considered brick veneer?
