Results 1 to 7 of 7
    Oct 2012
    Default blue toilet stains
    Has anyone had any luck removing blue stains (caused by minerals in the water from a drilled well?) from a toilet bowl? I have tried bleach and baking soda without success. CK
    Sep 2012
    11
    Default Re: blue toilet stains
    try a can of CocaCola, it has acid that may help
    Apr 2012
    143
    Try CLR (green containers) or a generic product that says "Removes Calcium, Lime and Rust."
    My 3 products in the order of use are cleaner w/ bleach, purple bottle Kapow or Bam, and then CLR. Read the label when using on surfaces, paint, aluminium, etc. Should be OK on Stainless steel & porcelain, but read.
    Jul 2009
    Washington state
    163
    Remove all the water and try a paste of 20 Mule Team Borax and vinegar. Let it sit for a bit then scrub.
    Or try scrubbing with Barkeeper's Friend.
    Nov 2012
    11
    Be careful with bleach. Any ceramic appliance manufacturer will tell you that bleach actually removes a very fine layer of the finish. Everyone uses it, but that's the fact of the matter. I've heard of the coca cola cleaner story several times before so there must be some truth in it.
    There's bleach free cleaners on the market now also.
    Dec 2012
    New London County, CT
    117
    For what it is worth we had the same problem and it disappeared after I installed a whole house sediment filter.
    Nov 2012
    Santa Ana, CA
    13
    A very easy domestic way can help you in removing stain. Cover the stain area with vinegar. Keep it as it is for whole night. Don't allow the toilet to be used by anyone. In the morning just clean it by using toilet brush.
    This will certainly get your stained to get cleaned.
