    Oct 2012
    Default Blown in insulation
    I want to put blow in insulation in my attic, the problem is that I have vaulted ceilings. Since I have vaulted ceilings I cannot install the rafter baffles without tearing out the ceiling. Are there any other options????
    Sep 2012
    11
    Default Re: Blown in insulation
    dont do blown in, its messy.
    Tennessee
    2,025
    If you have cathedral ceilings, then you either do not have an attic and you do need to tear out the ceiling to put in the baffles, or you have a scissor truss roof and you do not need the baffles. Either way, you should not do blown in, you must use batts.
