    Oct 2012
    Default Sagging header over sliding glass door
    The header above the sliding glass door from the Master Bedroom to the raised deck sags. It is not a big difference but sufficient to be noticeable and to allow water to run over the top of the gutter rather than running to the downspout at either end, during a heavy rain. The house is on a full poured basement with a walkout frame wall area immediately below the bedroom. A sliding glass door in the basement room is partially below the slider in question. There is insufficient wall above the bedroom slider to put in a taller header. Is there a way to fix this without replacing the slider with a narrower walk out door and siding over part of the opening? I have sandwiched steel plates to headers in similar situations but in this case there is only about two inches clearance between brick mold and soffit.
    3,158
    Default Re: Sagging header over sliding glass door
    Got a pic?
    Why not just re-hang the gutter in a straight (sloped) line?
    7,762
    If you can't put in a taller header, can you replace the existing header with a fabricated steel header?
    nova scotia, canada
    1,522
    what size is the existing header to begin with
