    Oct 2012
    Default Topper storage in a garage
    My husband and I are looking for a kit or product list that will create a system to hang his pickup truck topper from the garage rafters for easy storage.
    Anyone know what I mean and/or have any ideas?
    Sep 2012
    Boston
    1,004
    Default Re: Topper storage in a garage
    sure, if you watch the latest ask this old house episode which aried this past week they installed a pully system to hang bicycles from a garage ceiling...this could easily be adapted to accomodate your truck bed cover. if not, you can create a similar pully system from almost anywhere and easily adapt it.
    7,341
    Depending on how much it weighs, there are various ways to do it.
    I think the easiest would be to use a couple of pulleys and super strong wires. You can even install an electric winch for an easy hoisting.
    I once installed one of those for a huge and heavy chandelier and it worked fine (for lowering it for cleaning or bulb replacement).
    If this job seems like something you can't do, call some local general contractors for advice and prices.
    Oct 2012
    The bicycle hoists are similar to the idea we're looking for but they simply can't handle the weight of a couple hundred pounds of truck topper.
    I am looking to see if anyone has a kit that would do that same job but has already done the appropriate math and tensile strength research for hardware and materials.
    7,589
    Check out a place that sells truck toppers, they should have the type of hoist you are looking for at around a couple hundred bucks depending on what you get.
    http://www.campway.com/products/acce...cap/index.html
