    Oct 2012
    Unhappy The Bricks are in the way.
    I tried to help a friend update the wiring in a 'fixer-upper" around Boston, but we ran into a problem. Why do they put bricks & morter inside the bandboard & at the base of the wall between the studs above the floor in older houses? I never ran into bricks in old houses back in the midwest.
    Sep 2012
    Boston
    1,002
    Default Re: The Bricks are in the way.
    it's fire stopping used in baloon framed houses.....a ton of houses in mass have it. i run into it all the time. after you remove the bricks you have to replace the fire stopping, which you can do with "Roxul" Insulation in place of the bricks
    1,383
    Also foils rodents/snakes. Roxul won't.
    Casey
    Sep 2012
    Boston
    1,002
    rodents and snakes are not the reason for the bricks..
