Thread: Window Trim
    Oct 2012
    Default Window Trim
    I am refinishing and glazing the double hung windows in my house (3 over 1 I believe they are called) and I would like to replace the vertical trim pieces in the top window pane. At one time I thought I had seen adhesive backed muttons (?) that would take the place of the originals. I'd like to know if they are indeed available and where I can purchase them.
    1,522
    Default Re: Window Trim
    these mullions your asking about are available but with new windows. they get installed after the jamb extension are installed then installed.. you can more than likely order one from a local window supplier
    Sep 2012
    Boston
    1,002
    a second option would be to bring a window to a local cabinet shop and have them make one for you. usually not a big deal to do.
