    Oct 2012
    Question Radiant Heat on Uneven Floors
    Any specs I find for hydronic radiant floor heat systems say that it can only be used on level floors. Is this really true?
    If that is true... How can radiant floor systems be installed in old houses? Don't they make hydronic radiant wall panels? Doesn't the heated water circulate through the system by temperature differential and not by gravity?
    Jul 2009
    164
    Default Re: Radiant Heat on Uneven Floors
    The heated water is circulated through the system by a small pump, commonly called a circulator; and yes, radiant heat doesn't need level floors for this reason.
    Mar 2011
    26
    There is a company Pex Supply I would suggest you contact them at pexsupply.com and chat with a representative. I'm sure they will be able to answer your questions and address your concerns. Good luck on your project and please post back.
