Results 1 to 10 of 12
    Oct 2012
    Sault Ste. Marie, ON Canada
    9
    Question Tub Faucet stuck
    The pull bar on my bathtub faucet is really hard to change from tub to shower. So hard I have left it on shower as I doubt I can change it to tub then pull it back to open for the shower.
    How do I get this moving again? WD40? Another oil?
    Do I have to take this apart?
    Is it an easy fix or do I have to get a plumber? Hope not can't afford one on disability!
    South*East
    1,250
    Default Re: Tub Faucet stuck
    Are you talking about the transfer on the tub spout? If you are then just replace the spout.
    John
    3,160
    What John said plus;
    We like this one as they work flawlessly and don't drip.
    South*East
    1,250
    I to like the Delta spout. But I have had to instruct more then one customer on how to use it.
    John
    3,160
    We use it as an IQ test
    Feb 2012
    92
    It does seam to be the only spout that seams to keep all the water flowing to the shower head.
    7,762
    Seriously, if you are on a budget and can't afford a plumber, go to youtube and watch some demonstrations. Only you can tell if you can handle it or not.
    Oct 2012
    9
    Question Re: Tub Faucet stuck
    OK since reading some of the articles in here it's called the diverter is stuck. Main problem with changing to another spout is all bathroom fixtures are in brass, and everything seems to be brushed nickle or whatever finish now.
    So how do I fix the diverter stick? Oil, grease, have to replace the whole thing?
    7,972
    Quote Originally Posted by 4thjet View Post
    Not a question that can be answered without pictures or fondling the spout for ourselves. Odds are, if the plunger is on the spout itself and you can't operate it, then the plunger or its hinges are broken and can't be fixed.
    Remove the spout and inspect the plunger, hinge points, actuator rod, etc. Figure out where it is sticking and why, then from there determine if it can be fixed or must be replaced.
    Oct 2012
    9
    Thanks for the info A. Spruce.
    Sounds like replacing it would be the best idea.
    For now just keeping it open for showers, then when I can will get a new faucet.
