Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    Oct 2012
    Sault Ste. Marie, ON Canada
    9
    Default Re: Kitchen Sink - Help!
    I don't understand how the strainer can cause the water to drain all over your feet. Do you have a normal drain system under your sink?
    Yes I've seen the strainers in TOH and in stores now, and that's the piece that came right off. It also was disconnected from the pipe underneath. I've never seen anything like this happen at all!
    Yes I have a normal double sink plumbing job under the sink.
    Here's what happened:
    I had been soaking some dishes, and when I started rinsing them off and took the plug out while rinsing then everything came apart. The suction from the plug must have pulled on the basket strainer just enough to make it let go. However it also disconnected from the pipe underneath the sink.
    I didn't notice for a minute and water draining from the sink/dishwater, missed the outflow pipe as the strainer was no longer attached to either side of the sink or pipe, and run out of the cupboard onto the mat I was standing on.
    It's a double regular kitchen sink and it's the main line side that came away from the sink and the pipe underneath as well as the strainer came right out into my hand. I found the washer and put it back under the strainer and hand tightened the nut/screw underneath the sink on the pipe.
    Obviously not a perfect job and still leaking a little but now have a bucket under there to catch the leaks.
    So before I super tighten everything, get plumber's putty etc. should I bother? or just get a whole new sink or just the strainer?
    Hope that made it a bit clearer. Sorry I can't provide pictures my phone takes them dark and the older camera is unreliable.
  2. #12
    7,357
    I bet your strainer gave due to corrosion, but whatever the reason, it ought to be replaced. No need to replace the whole sink.
    A new strainer is less than 5 bucks. You need some basic plumbing skills and some hand tools. Install it with plumber's putty. Good luck.
  3. #13
    Oct 2012
    9
    Thanks for the advice DJ.
    Glad I finally made it clear what happened and what the part was!
  4. #14
    Tennessee
    1,908
    Now I see the problem. I got confused when you mentioned seeing these at Walmart, you won't see what you need there. The whole drain unit is called the strainer, the part that acts as the plug and actually does the straining is the basket. I am including a link that I think shows the best picture that I can find, this is not a recommendation.
    http://www.homedepot.com/webapp/wcs/...N#.UIF74t3X5e4
    These come in different sizes so be sure to measure your current strainer before you buy a replacement. You can see in this one that there are actually two cup shaped bottoms, one fits inside the other and they screw together using the integrated nut on the outer cup. You separate the two pieces.
    Get some plumbers putty, take about a 1" ball and roll it between your hands until it forms a rope about 1/4" think and long enough to go all the way around the lip of the inner cup and overlap a little. You may need to adjust the size of the ball you start with to get this right, and it will probably take a few attempts to get it right, only the pros get it right the first time.
    Then drop the inner cup into the hole at the bottom of the sink. From under the sink, place the rubber gasket on top of the outer cup and slid it up under the inner cup and start screwing to the inner cup. Tighten down securely. You should see the plumbers putty squeezing out from around the inner cup into the sink basin. When it is tight, you just sc**** the excess plumbers putty away. Then attach the rest of the drain pipes.
  5. #15
    Oct 2012
    9
    Smile Re: Kitchen Sink - Help!
    Thanks for the picture and play by play keith!
    Yes that is the whole part that came out. The ones pictured are obviously for a better grade of sink than I have, but yes it's the part I was talking about.
    I did see in one of the plumbing videos Tom do what you are talking about with the putty....amazing how they make it look so simple eh?
    In the meantime, not totally filling the sink, or putting the plug in is holding the make shift job together until I get some putty and check out underneath the sink.
    Think I will call a friend who remodels bathrooms all the time and see if he has some instead of buying a whole jar of putty for 1/4 inch piece, he would probably fix it anyway.
    Thanks all for your responses and advice!
  6. #16
    Oct 2012
    10
    Again, without pictures or personal inspection, we can't tell you anything about the strainer or the drain system.
    From the sounds of it a new strainer may take care of the problem, but this is only a guess from the limited information provided.
    How can anyone add a picture if this site says "you need to post atleast 10 messages before adding a link or attaching picture to this thread".
  7. #17
    South*East
    1,242
    Try typing your link with quotation marks. Then we can copy and paste the link less the quotation marks. Someday, hopefully they will allow links without having to have ten posts.
    John
