Results 1 to 9 of 9
    Oct 2012
    Default Door Frame Dry Rot Help
    I live in a 10 year old house with an exterior door frame that has dry rot at the base of the frame. We recently had our house painted and the contractor just painted over the frame and didn't notice the issue. Somehow, our new puppy started chewing on the door frame and was able to dig a huge chunk out of the frame.
    I started investigating and saw that a huge portion of the lower frame had dry rot. My question is can it be repaired and how or should I replace the entire door/door frame?
    frontelevation.com/photo1.jpg
    frontelevation.com/photo2.jpg
    Thanks,
    Robert
    6,045
    Default Re: Door Frame Dry Rot Help
    Any half way decent carpenter should be able to cut out the rot and install a dutchman.
    7,762
    Replacing damaged portions of door jambs is normal practice.
    Mar 2011
    26
    You can repair the jam or replace the the whole door but if you dont take care of what caused the dry rot you will have the same conundrum down the road. Dry rot is usually caused by water infiltration. The door may have been improperly flashed or a drainage issue where the jam wicks up water and or water is constantly splashing up on the door. good luck on your detective work and the repair. Please post back as to what you find and do to correct the issue.
    Oct 2012
    29
    You need to replace your whole door because it may be structurally damaged by the rot and then you have to take steps regarding the prevention of dry rot. The most important way to prevent dry rot is eliminate excess of moisture from home.
    2,011
    You probably don't need to replace the whole door, just the bottom part of the frame. The design of the door frames made today make them very hard to keep water out. I prefer a sill that goes all the way across and under the frame on each side, water is more likely to shed that way, but todays doors have the frame going all the way to the foundation and a metal sill that only goes to the frame on each side. Once water starts down that frame, it is going to get by the sill and all the way to the foundation.
    You can cut away the rot and have pieces of wood cut to fit the cutouts, but it might be easier to just replace the frame. You can buy a pre manufactured frame that will be pre primed on all six sides. If you are hiring out this job, the pre manufactured frame will probably save you money in the long run.
    Before installing the new frame, I would top coat all six sides of the frame as well, two coats on the inside and bottom, put the second coat on the outside after installation. Caulk at the bottom with a silicone caulk. While you re at it, you can reinforce the frame by gluing spacers between the frame and the frame of the house and then using 3.5" screws to hold the door frame in place. Done right, this can make kicking in the door a very painful experience for anyone who tries it.
    The last step is protecting the door frame from water in the first place. since it got water damage in the past, I'm guessing that you have little to no overhang (eave) above the door. You need a good overhang, at least 3 feet, OR a good storm door. This will keep water off the frame and sill.
