    Jul 2012
    9
    Default Kitchen faucet w/pull-out sprayer woes
    I recently remodeled the kitchen and included a not-cheap fancy name-brand single lever faucet with the popular pull out spray feature. It was a bear to install but that's not my problem.
    We now get very low water volume. It takes almost 10 minutes to fill one side of the double sink, about 30 seconds to fill a 2 quart pitcher, and almost as long to fill the coffee pot. Also, for hot water, it now takes well over a minute before it starts to get warm. This wasn't a problem with our old plumbing and I have adequate city water pressure.
    The water column looks adequate because of the aerator but obviously it's mostly air. I figure I'm getting about 1 gallon per minute. I've checked elsewhere in the house, I get at least 5 gallons per minute at the garden hose (I checked when filling the swimming pool).
    I used the existing supply pipes when installing the new fixture and volume wasn't an issue before.
    Examining the pull-out sprayer, it appears that all the water must pass through a .25" OD pipe(no idea of the ID).This must be the problem!
    In all honesty, my wife is thrilled with the new kitchen, it's just me(for now) noticing the problem.
    I'm thinking there's no solution here but I would appreciate any suggestions.
    Sep 2012
    Boston
    993
    Default Re: Kitchen faucet w/pull-out sprayer woes
    there's a few things you can do to make sure you're maximizing the water flow. 1st, check the specs on the faucet and see what the gpm is. 2nd, unscrew the screen guard where the water comes out and make sure the screen guard and flow restrictor are not clogged up with sediment. this is supposed to be done prior to turning the water for the first timne when you install the faucet. 3rd, if #1 and #2 don't solve your problem then disconnect the hose at the shutoff valve and make sure nothing is restricting the water. if none of those work you can remove the flow restrictor which sits against the screen which i mentioned in the first option.
