    Apr 2009
    Griffin, Ga
    Default water pressure problem
    I live on a farm with one well supplying 2 homes. The well is drilled w/ a 1 1/2 hp submerged pump. There is a 1" pvc pipe running about 1/4 mile across a field that feeds our home. We have only 20# or less of water pressure. We have been told short of replacing the water line with 2" or bigger and/or drilling our own well the problem cannot be eradicated. I am looking for viable options that will fix this problem permanently for a much lower cost. Are there any fixes available that WILL work and not just MIGHT work. Thanks, David Lamb
    You will never thirst again when you drink the water that God offers!! His is the Living Water!!
    Feb 2009
    693
    Default Re: water pressure problem
    I think God will fix it.
    Apr 2009
    Griffin, Ga
    Smile Re: water pressure problem
    God probably has a whole lot more important things to do than to fix my water problems. Possibly to save the lost and to help His creation through life would be major undertakings all on their own, wouldn't you say?
    John 3:16 - Try reading it, you might be changed for eternity!!
    Jan 2009
    Needham, MA
    559
    how about installing a holding tank in your basement. the well pump can fill it up at any pressure then you put a new pump on the tank and get 60-65psi from that into the house. much cheaper than drilling a new well.
    Apr 2009
    Griffin, Ga
    What sort of pump are you referring to. Is this a relatively cheap pump or are we talking lots of money for it. Also how would I hook up my existing line to it.
    6,115
    Pressure booster pump http://www.amtrol.com/pressuriser.htm You'll have to check prices locally.
