    Sep 2012
    8
    Default Blistering Paint on Clapboard..why?
    Hello,
    We purchased a 1890's era house on the Front Range of Colorado a little less than 2 years ago. We have a problem with blistering paint on the north side of our house. When we removed the blistered paint it exposed the bare wood underneath. From all the info on the internet, this would suggest that we have moisture building up from inside. The problem is that we can't figure out where the moisture might be coming from. We did install a humidifier on the downstairs gas furnace last fall (because we have incredibly dry air) but that only humidifies the downstairs. Most of the blistering is occurring on the exterior of the second floor. And most of it is happening on the exterior wall of a walk-in closet. The closet has a heating vent but we shut it off last year to conserve energy. There is virtually no blistering on that wall in the area of the upstairs bathroom, however, where we would be more likely to expect it. The sofit extends quite a distance over the portion of the wall that is blistering and we cannot find any leaks in the gutters or the roof. We're stumped! Any ideas?
    Sep 2012
    8
    Default Re: Blistering Paint on Clapboard..why?
    Just realized I probably should have posted this on the "Exteriors" thread!
    1,522
    90% of the time its do to excessive moisture.
    if the siding is painted when its not completely dry throughout the moisture will want to migrate out of the wood through the face which will blister it. . also not having primer on it will do it
    for this reason all wood siding is required to have a rain screen installed first so to allow for even drying.. it creates a air space behind the siding so the face and back can both dry out evenly
    1,932
    Catmomtoo,
    I have posted a reply to your question under your oriinal post under the DECKS section.
