    May 2012
    Default radiant floor hot water heating
    i have 500 sf house to heat. i was told that i can run a radiant floor hot water heat system off a hot water heater with a circulating pump. anybody have any experience with that? what size hot water heater?
    South*East
    1,257
    Default Re: radiant floor hot water heating
    That isn't a question that can be answered without more information. What you need is a heating contractor to do a heat loss on the home. That will determine the size unit you will need to use and how many feet of tubing will be required in each room.
    John
    Greater London
    You can also make a research about different solar water heating systems. They are a bit more expensive than the other versions, but this is a great alternative for a home like yours.
    Believe it or not, I know many things about home improvement and this is not only, because I am working for the best Hidden Content . Thanks to the hundreds of DIY projects that I've been making on my own for the last few years I've learned many things about how to preserve a home good looking.
