    Default Need Fireplace Brick Insulation
    Help! I'm in the process of renovating my kitchen. On one wall there is a fireplace. The Building Code in my town says that there needs to be 2" to 4" of space between the brick wall and any combustible material, like kitchen cabinets. I don't have the room to do this. So my question is what kind of material can I put on the brick (the backside of the fireplace) so that I can attach the cabinets to the brick? It must be something that is well documented and the Building Inspector will approve. Help, "OB1, you are my only hope."
    6,751
    Default Re: Need Fireplace Brick Insulation
    Ask the inspector if a sheet metal shield will be acceptable.
    Oct 2012
    The inspector may allow for a rated duct wrap to be installed or mineral wool. Again you would need to ask.
