    Sep 2012
    Default Low hot water pressure
    My house was built 11 years ago. I have two bathrooms upstairs. In my master bath, it takes more than 20 minutes to fill the tub with hot water. The pressure is extremely low. When I turn the water to cold the pressure is strong.
    In the other full bath upstairs, I have equal strong pressure when filling the tub using both hot and cold water.
    What can be the issue in in the master bath, and what can I do to fix it?
    South*East
    1,242
    Default Re: Low hot water pressure
    What make faucet do you have? It sounds like it may be a balance pressure valve with a sticking balancing spool.
    John
    7,344
    In addition to what John says, it could be a blockage in the water lines, even though unlikely for an 11 year old house it could be possible. What kind of pipes do you have?
    If your faucet has 2 or 3 handles, there could be some defect in your stems.
    Sep 2012
    Quote Originally Posted by johnjh2o View Post
    John
    The only thing stamped on the faucet says "Watco". It is a simple one knob unit.
    Thanks to all for the feedback.
    South*East
    1,242
    I think all they make are tub wastes. I don't think they make faucets.
    John
