    Sep 2012
    6
    Default Finishing Basement with Hidden Doorway
    I'd like to finish our basement but I'm not sure where to start. I have a basic idea of what I'd like. I'd like to split the basement in two creating a utility area on one side (water heater, boiler, washer dryer, sump & well) and then living area on the other side. I also thought it'd be kinda neat to have a hidden doorway through a book case. Any ideas on that? Should I have it swing with casters on the end or push in and slide over... what's the best way?
    8,065
    Default Re: Finishing Basement with Hidden Doorway
    Swinging out would be the easiest to do and conceal.
    Sep 2012
    Boston
    1,002
    spruce is right but you can buy kits that you put together. look ****** for them.
    Oct 2012
    29
    Its such an Important part I think you should get proper idea from any professional!!!
    Nov 2012
    central pa
    98
    i worked as a custom cabinet maker and designer for 12 years full time and built 8 or 9 hidden passages. the easiest is to build it into a paneled wall. then just have one ov the panels swing out of the room away from the moulding. i found bookshelves work best swinging also. i think it is easier to conceil swinging away from the finished room. we always used casters under the whole cabinet and a floating hinge that would let the cabinet rise and fall with changes in the floor
