    24
    Default Glue recommendation
    Can anyone give me some advice on which would be the strongest glue to use on the joints of my 6 panel interior doors which have a tendency to spread apart every few years. I probably haven't removed the old glue thoroughly but I will do this as soon as I can think of the appropriate tool for this application.
    (Could use some ideas on the tool as well) Thanks everyone.
    6,080
    Default Re: Glue recommendation
    Personally I like Titeband III. The other thing you can do is pin the tongues with dowels once the door is clamped together tight. Pocket screws can also be used if installed properly. That is so they are not screwed into end grain.
    24
    Thanks Jack for the quick reponse. Your knowledgeable advice is always much appreciated.
    Guy
    Apr 2012
    216
    Smile Re: Glue recommendation
    This is the best glue in the world If I one day learned that NASA used it for the space shuttle I wouldn't be surprised The next time I order some it will be in the gallon size instead of the 16oz. size. The only thing I don't like about it is the long drying time, but it's worth it.
    Mar 2013
    12
    Good to hear about Titeband III, I'll have to see if I can find it locally, for my projects. Thanks.
