Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. #11
    Apr 2012
    216
    Smile Re: Completely Perplexed.
    Quote Originally Posted by The Semi-Retired Electric View Post
    I believe you made a wise decision to forget how they did it and concentrate on how it should be done.
    Thanks Semi-Retired Electric I did some testing yesterday and found that they used one neutral for all the lights in this branch. Seeing how some of this K&T gets wired I was relieved and happy to see that. I capped the neutral and hot in the main box and now I'm trying to figure out how to group the new wiring. I think I'm going to have a separate breaker for each room. So for the bedroom I'll have 3 receptacles and the light on one breaker. For the living room I'll do the same thing. Does code allow this? Which leads me to my next question;
    Each bath should have it's own 20A circuit and the receptacle should be GFCI protected.
    The bath does have it's own GFCI BUT it's a 15 amp GFCI/breaker. They didn't run anything downstairs at 20 amp. All the old K&T was 15 amp. Is that OK?
    Here is how the bathroom is currently wired; The GFCI is on its own 15 amp breaker. The heated floor is very small (3' X 2') and is only 1 amp. It is also on its own 15 amp breaker. The bathroom lights were on the old K&T wiring that I'm replacing now.
    Would it be OK to tap off the GFCI for the bathroom lights? Or does the GFCI need to be on its own breaker? Can I tap off the heated floor thermostat to feed a nearby hallway light?
    Generally, AFCI breakers are required in all areas that do not require GFCI protection. When in doubt install them, they're designed to offer superior wiring protection and some shock protection as well.
    Yes I want to use AFCI throughout the house. However it's a Square D panel and I'm trying to find out if I can use GE or Eaton Cutler Hammer AFCI breakers. Also the main panel is now full and I need to add 3 more circuits to it to replace this old K&T wiring. I've never seen a tandem or dual circuit AFCI, so I may need to add a sub-panel.
    THANKS for all of your help in sorting all of this out
  2. #12
    Jan 2011
    Columbiana, Alabama
    843
    Default Re: Completely Perplexed.
    That sounds fine.
    The Code calls for 20A
    That might be adequate, but not quite up to Code.
    Sounds like it’s very lightly loaded.
    Good
    I would tap off the heated floor circuit, since the bath receptacle is already marginal
    The bath receptacle should not have anything on it except the bath
    That’s what I would do
    You will have to use SQ D AFCI Homeline or QO AFCI’s depending on the model #
    Can you create space in your panel by replacing a 2 pole full size breakers with a ½ space 2 Pole?
    True, if you go w/ a GE or CH you can put in their AFCI’s
    My pleasure, let us know how your project is coming..be sure to turn off all power before changing breakers, panels etc. A short in there can create not only a shock hazard but a huge fireball.
    BTW, how large is the transformer feeding your house and how far away is it? You may need a panel(s) with a higher than normal (22 Kaic rating). Usually, if it’s an overhead feed and more than 50 ft from your house a standard 10 Kaic panel is fine.
  3. #13
    6,114
    The reason for 20a in the bath room is because of hair dryers which in many cases is a full load for a 15 amp circuit. Running the bath lights off the 15 amp circuit could leave some one in the dark if a hair dryer trips the breaker.
  4. #14
    Apr 2012
    216
    Question Re: Completely Perplexed.
    So just to clarify, I can tap off the floor thermostat (15 amp breaker) for both the bathroom AND hallway lights? Just pigtail the connections in correct?
    I don't know. What (or how) would I find this out at?
  5. #15
    Apr 2012
    216
    Oh my god, I just figured out that our 1875 watt hair dryer is 15.62 amps
    Time to upgrade that outlet to 20 amps....
  6. #16
    Jan 2011
    Columbiana, Alabama
    843
    Quote Originally Posted by MyMilan View Post
    True, the only reason you haven't had tripped a breaker is because the 15A breaker can run in an overloaded condition for several minutes without tripping.
    Short term it would be better to get a smaller hair dryer until you run a 20A circuit.
    Yes, you can use the floor heater circuit, if it's 120V and only pulls 1A, to power your hall and bath lights.
    You can call your power company engineering dept. they will be able to tell you the short circuit available current to your home. Chances are it's well below the 10Kaic number you need to worry about. The answer will be free and if it's too high it's better to know sooner than later.
  7. #17
    Apr 2012
    216
    Luckily it has a lower fan speed option that I will use. Was really surprised to see how many amps it was pulling. Because of this I have decided to run 12/2 for all the new main floor recepticle wiring. I will only use 14/2 for lighting. The only exception will be the living room lighting because one day I plan to install a fan in there, so I'll run 12/2 for those lights.
    So I want a lower number?
    What does this number tell me about my house wiring?
  8. #18
    Jan 2011
    Columbiana, Alabama
    843
    Yes the lower setting would solve the problem short term.
    I carry #14 wire but have not used any for years. True it's easier to wire and box fill is less of a problem but you're limited to about 10 receptacles (or lights) with 15A (#14 wire) so you would have 20% more "home runs" and now that we have to install $45 AFCI's (15A & 20A cost the same) so IMO there is no good reason to use #14 anymore.
