Results 1 to 10 of 10
    7
    Default basement bath venting
    Could someone be so kind as to sketch on this image where they suggest i put vents?
    I seem to get conflicting advice whether one vent is enough or if each appliance (shower, lav, water closet) needs its own vent.
    thx
    https://dl.dropbox.com/u/79088836/plumbing05092012_00000.pdf"]https://dl.dropbox.com/u/79088836/plumbing05092012_00000.pdf
    3,158
    Default Re: basement bath venting
    One decent vent is all that is needed. They are sized in CFM's due to room size. Panasonic makes some excellent, very quiet fans
    7
    this is a plumbing issue but thx!
    Jul 2009
    Washington state
    230
    Maybe you should post this in 'Plumbing'.
    1,002
    from looking at your picture i would run the vent straight up behind the toilet then tie the sink and shower into that pipe in the wall above the high level water mark of the sink. looks pretty simple to me.
    7
    so a T right below the toilet flange?
    1,002
    no T's allowed on the drain side, only on the vent side. install the toilet drain with a wye to the sink upstream of the toilet and a wye to the shower downstream of the toilet. then the toilet vent goes up the wall behind the toilet with a T for the shower and sink vents up high on the wall above the high water line of the sink.
    7
    nice, thanks pal!
    7
    does this look ok?
    https://dl.dropbox.com/u/79088836/plumbing05092012_00001.pdf"]https://dl.dropbox.com/u/79088836/plumbing05092012_00001.pdf
    Aug 2012
    NY, USA
    18
    Hi
    You need to go across the basemen.Please, check you local plumbing code.
    Thank u
    lean and tone
