    Aug 2012
    Wisconsin
    Default Staining or tinting wood floor
    Removed the linoleum floor glued to the 105 year old maple flooring. Here is my dilema - the gorgeous pumpkin patina is now gone and I am left with a room nearly white in color with the remainder of the house filled with the darker color. How do I go about approximating the vintage color? I have thought about dying or possibly staining the wood as I don't think modern floor finishes will ever darken or turn a dark amber color with age.
    Jun 2012
    19
    Default Re: Staining or tinting wood floor
    Strip and sand all then make it a new
    Feb 2012
    Tacoma WA
    87
    Pick a piece from the floor that was sanded and one that you want to match, preferalbly from a closet or other hidden place. Bring them to a paint store and let them match it for you.
    Sep 2012
    Florida
    28
    Use an oil-based polyurethane and NOT a water based. The oil-based gives a slight amber hue to it and will continue to darken very slightly over the years. The water based finishes are not as good in my opinion and give a very clear cold finish.
    Also, you can stain the floor any color you want. Just pic the color and let 'er rip.
    But stick with the oil-based poly for your floor. We do tons of floors every year and that stuff holds up better than the others. I personally like Fabulon's oil-based poly the best.
    62
    A natural oil finish would probably give you the look you are going for. Also, I think that asking painters what would match is a good suggestion as well. You essentially need to make sure that the finish is appropriate for the type of surface you are finishing.
