Results 1 to 10 of 13
    Apr 2012
    216
    Question 20 Amp Recessed Receptacle?
    Is there such a thing as a 20 amp recessed receptacle? It would look like this only with a 20 amp T slot:
    Recessed receptacle
    Default Re: 20 Amp Recessed Receptacle?
    Why won't you buy the box and the 20A receptacle separately?
    Then you can combine the two. Go to a local electrical supply place and find out.
    Apr 2012
    216
    Question Re: 20 Amp Recessed Receptacle?
    I have never seen a recessed box or faceplate. Any links?
    Went to Loews and Home Depot but no joy.
    Yes, google 'recessed receptacle'. They are handy when you want an appliance or a TV flush with the wall.
    Columbiana, Alabama
    843
    Quote Originally Posted by MyMilan View Post
    Recessed receptacle
    Hubbel has a 120V 20A stainless steel recessed "Clock Receptacle".
    It is a single unit with the standard 5-20R T slot and sells for about $25 on Amazon.
    It's made to go behind clocks, TV's, beds etc. so the plug won't hold the "clock" off the wall.
    Apr 2012
    216
    Smile Re: 20 Amp Recessed Receptacle?
    Thanks guys! I found this one for six bucks, so I ordered two. I'm really looking forward to installing them
    Columbiana, Alabama
    843
    Great! If the receptacle you're installing will be the only receptacle on a 20A breaker, the receptacle should be rated 20A.
    Apr 2012
    216
    There are 3 receptacles on the wall, all 20 amp.
    Columbiana, Alabama
    843
    If the're all on the same breaker (15A or 20A) you're fine w/ 15A receptacles, which have the same gauge internals, in most cases and cost a lot less.
    Apr 2012
    216
    Yes they are all on the same breaker, but I was going with 20 amp receptacles because I was afraid that a 15 would be the weak link and a possible fire hazard. I know that they under rate receptacles and others use 15 amp receptacles on 20 amp circuits, but I just felt safer keeping everything straight 20 amps. I'll be using all AFCI breakers too.
