Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    5,836
    Default Re: Very old 3-way switch
    Here's a picture of the switch
    It appears that it only has one set of wipers and the screw is missing on one position. It appears to be a two position switch rather than a 3 way. It makes contact between 12 and 6 or between 3 and 9.
  2. #12
    Aug 2012
    10
    ok, so now on to the important things....do i just go with a regular switch or cut the wall for the box and maybe find the wire and put in a double gang box???
  3. #13
    Columbiana, Alabama
    738
    Quote Originally Posted by kj4ltc View Post
    Go with a regular 3w switch for safety, but,what you have could be used as a three way if you jumpered 3 to 12 (to create a "common" and use 6 and 9 as travelers.
  4. #14
    Aug 2012
    10
    So, you're saying wire it up as a 3 way ?
  5. #15
    5,836
    I disagree. As it is now, it has a single wiper and it has power on 12 and would switch power on and off on 6, it never powers 9. Installing a 3 way you could end up applying power to wire that you don't know where it goes. I would install a single switch.
  6. #16
    Aug 2012
    10
    thats what I was thinking Jack
  7. #17
    Columbiana, Alabama
    738
    No it is old and the wipers probably have excessive contact resistance (safety issue) and it is not "listed" so would not meet Code.
    But if you did what I said in post #13, technically, it could function as a 3 way switch.
    I created a CAD drawing of the four possible switch positions but this forum will not allow me to post it, or I haven't discovered how to do it yet.
