Results 1 to 10 of 17
    Aug 2012
    10
    Default Very old 3-way switch
    Hello all, first time poster here! I am currently replacing switches in our 1920 1.5 story Kentucky home. I have run into what appears to be a 3-way switch, it is round and has "reed" like contacts inside. The switch is operated by turning 90*. My fluke multimeter shows 120VAC on one lead and nothing on the other 2..... Onto my question- how do I wire my new 3-way switch???
    6,024
    Default Re: Very old 3-way switch
    If you have a constant 120 v on one wire connect that to the common screw and the other two wires as travelers
    Jack.
    Aug 2012
    10
    Ok, thanks jack! I'm not sure if it was supposed to be a 4-way and a terminal is missing or something. The switch is circular and has 4 terminals...at 12, 3, 6, and 9 o'clock positions. The 120v is at the 12 position, there are wires (possibly travelers) at the 6 and 9 o'clock positions...the switch joins the opposing terminals only (ie... 12 - 6 and 9 - 3) that's why the single wire (9 o'clock) is confusing me..maybe a picture would help?
    6,024
    That does not sound like a 3way or a 4way. If it connects 12 to 6 or 3 to 9 it sounds like a 2 position switch. With 120 v on 12 then the out put is on 6 and those would be the wires you connect to a single switch. not sure what the wire on 9 is for, unless your reading of the closures are incorrect.
    Aug 2012
    10
    There is a terminal at 3' but there is no screw in it
    Aug 2012
    10
    sorry, cant figue out hot to upload image.
    6,024
    E-mail picture to me jackson_l_mcdaniel@yahoo.com Put TOH PIC in subject line and include your TOH Username And I will posy it for you.
    Columbiana, Alabama
    843
    Jack gave you the way to wire it as a 3w in post #2
    But if there is no screw at 3 (and 3 to 9 switch) the wire at 9 was not being used.
    So, it was only being used as a single pole on-off switch 12 to 6.
    If the switch is actually the reed type some contacts could have been blown away during a short circuit.
    If the switch operates at 90 deg. and can be rotated continuously in one direction there must be an wiper rather than internal jumpers.
    Since you have a "fluke" I suspect you will figure this out soon.
    That switch seems very rare, I wouldn't throw it away until I knew more about it.
    Aug 2011
    Northern Indiana
    103
    I there another switch that controls the same set of lights? If not, it is not a three way switch.
    6,024
    Quote Originally Posted by brrichter View Post
    Not necessarily true. Any three way switch can be used as a single.
