    Apr 2012
    143
    Default What Finish Was Used on My Parquet Floor ?
    My main level floor is original 1964 9" square parquet . . . any guess as to what finish was used ? wax ? was polyurethane around in 1964 ?
    So far, in a year, we have not used any cleaner; just vacuuming & Swiffering. We used Bona for spot cleaning even though we don't know the finish.
    We suspect the previous owner's housekeeper (sometime in 45 years) used water-based liquids because there is noticeable shrinkage and noise (walking causes the tiles to strike the concrete base or each other). (We didn't detect it as the seller had a lot of area rugs.)
    The finish has a slight shine . . . not a noticeable dull which I would expect for a wax.
    Any way to test by using different cleaners ??
    The house was built by a neighbor builder for his retirement, so his contractors used mostly good materials and presumably didn't skimp on workmanship.
    Thanks.
    Apr 2012
    143
    Default Re: What Finish Was Used on My Parquet Floor ?
    Any ideas for the above ??
    6,053
    It could be shellac, Try some alcohol in a place not noticable and see if it dissolves the finish.
