Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    Default Re: Okay to use flex water line instead copper pipe to dishwasher?
    John,
    True. I've never seen a dishwasher with the inlet on the right side. But since the exact location of the inlet varies slightly between the different washers, I can see how a custom copper tube won't fit a new dishwasher.
  2. #12
    Apr 2012
    143
    If you move a dishwasher away from the sink, you'll need a longer water supply line and a waste line.
    [/QUOTE]
    Good point. The supply line is easy with the 8 ft kit.
    The drain line would stump me if it was short. My Bosch DW's drain pipe is thin accordian frosted plastic, with rubber connector ends & clamps; they look iffy for 10-12 years service which I expect from the Bosch (assembled in the US with US & foreign parts).
  3. #13
    I'm familiar with the Bosch drain line. Call Bosch and see if they make a longer drain line, when and if you need it, or fabricate an extention piece to tie into your existing drain hose.
    I think you should get more than 12 years from your dishwasher. BTW, are you satisfied with its performance?
  4. #14
    Apr 2012
    143
    (1) The drain line is plenty long, but the ends seem unique that it can't be patched.
    (2) Cost pressures make manufacturers skimp, and heat does a number on the electronic components. happy to get 10-years; thrilled with 15 years.
    I had a base Sub-Zero frig (built 1996 $4,000, $7,000 today) still going strong, while my previous $1,000 electronic Kenmore DW (probably by KitchenAid) crapped out after 3 years.
    (3) I had a Bosch in Calif, and a mid-line SS ($630) one here in VA (more plastic & less expensive). Both are quiet enough, and wash well. As a group, they are predictably as or more quiet than other brands at each price point. BUT, uninformed users are frustrated by the "natural dry" cycle (no electric dry) -- plastics like food containers are still fairly wet but earthware are nicely dried. People with hard water & non-phosphate detergent are also frustrated.
    For spot free drying, have to use Jet Dry.
    I would buy anything Bosch Gmbh makes; the Germans have pride in designing & making top-end products (but are not mistake proof). Continental Tire, Miele, Braun, BMW, etc.
  5. #15
    t_manero,
    you're right about Bosch products, even though I like to buy 100% made in USA (parts too).
    When I was 17, my uncle handed me an old, rusty ARIEL motorcycle and said: fix it and it's yours! With very limited funds, the first thing I did was to replace the spark plug with a new Bosch plug. Well, a few week later it was running, and very quickly I sold it, only to buy a used TRIUMPH. But I didn't keep it very long - I upgraded to a 4 wheel car...for safety concerns.
