Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. #11
    1,901
    Default Re: Threaded hole for grounding screw - upgrading from 2-prong to 3-prong outlet
    The ground wire must go from the receptacle to the ground in the panel, not from a box to the panel.
    Something you may be missing here... it sounds like in the OP's case, there is no ground wire in the box; ground is provided by the conduit. So the ground screw on the receptacle needs to be bonded to the box.
  2. #12
    Columbiana, Alabama
    843
    Actually, if the box is properly grounded by conduit Art 250.146 allows us to simply fasten the receptacle to a metal box, after removing removing at least one of the two insulating washers, with the two screws provided.
    I'm not a big fan of this method but a standard receptacle yoke will be legally grounded by doing so.
    Many jurisdictions require a short wire from the receptacle ground screw to a metal box screw or clip. And, many required a green or bare wire from the box back to the power panel, even if in metal conduit. That's what I do no matter what the jurisdiction says, a good receptacle ground is too important to rely on conduit set screws or locknuts.
  3. #13
    Aug 2012
    new york
    6
    Default
    I recently renovate my house and now it looks eye catching and beautiful. I got information about electrical stuffs and other lighting products right here from this forum. I purchased these and made my house superb.
  4. #14
    Columbiana, Alabama
    843
    Quote Originally Posted by Jaylenn View Post
    Great Jaylenn, glad we were able to help. Thanks for the thanks!
