    Jun 2012
    19
    Cool Metal drain pipe
    I have a 2" in drain pipe that is threaded to the riser going down into the basement. I want to remove the section that is threaded and replace with pvc. I cannot budge the piece even with a 24"pipe wrench. Since i cannot remove the section is there a way to bond pvc to the metal piece without threads? then install my bowl sink and trap assembly. Thanks
    South*East
    1,252
    Default Re: Metal drain pipe
    You can use a banded coupling.
    http://www.fernco.com/plumbing/shiel...flex-couplings
    John
    7,762
    Cut the metal pipe with a recip saw and install one of those no hub couplings and you're good to go.
    They are sold at HD and Lowes as well.
