    Aug 2012
    Default Exterior trim around window
    I accidentally cut the siding too far back so there is half an inch to 3/4 of an inch gap between the siding and the new trim. I fear that caulking the hell out of it is not going to look good. Any other ideas?
    Jan 2009
    Needham, MA
    559
    Default Re: Exterior trim around window
    remove the trim board and rip a new one to the proper width, if you have a 1x5 trim board on there now, but a 1x6 and take 1/2" off the width of it.
    Aug 2012
    new york
    6
    Default
    I recently renovated my house. I was looking for windows for my exterior areas. Some one told me about exterior trim around window and I managed to fulfilled my requirements.
    Sep 2012
    Florida
    28
    I agree with MLBSF. If you try to caulk it even with a backer rod in the gap you'll have problems later. But if you don't want to have to redo all the exterior trim boards to match you're better off replacing the one piece of siding. Unless you have a board stretcher. ;-)
