    Aug 2012
    Question framing question
    I was hoping I could get some help here without going to a architect. I installed 2 micro lam beams that are 9"5inch wide, 2in thick, and 16ft long. The beams are holding 11 joists one side the joists go out 13ft on 1 side, and the other side goes11ft. This is holding up the second floor where there are 2 bathrooms. The Micro lam beam has bent a little so I wanted to re-support with a steel fitch beam. My question is which size steel fitch beam is best, 1/2in or 5/8th?
    Nov 2009
    71
    Default Re: framing question
    You need the services of a structural engineer or an architect.
    Only they will be able to calculate the loads both live and static.
    Then you can size the beam correctly.
    Jan 2009
    Needham, MA
    559
    ditto !!!!!
    7,358
    I agree too, their fee will be money well spent.
