    Apr 2008
    Kansas City area
    48
    Exclamation Fencepost extension
    Can someone please give me abit of advice how's the best way to attach a wood fencepost extension? I've had to rebuild parts of the fence to keep my dogs in and add height to keep vandals out. I have a section of 10' long X 4' high picket fence that is connected to the neighbor's 8' privacy fence. Anywho, my side of new fence will be raised to 6' and the corner has a gothic style finial that will hold the 4x4 24" extension (it has a finial). Should I cut that off and use a metal brace or cut wood braces and screw them into the top rail? I also read to make shiplap cuts as the means of support. I'd appreciate any input - this is my first fence to fix. thanks!
    6,403
    Default Re: Fencepost extension
    To have a 6' tall wood fence, you first have to frame it for that purpose. That means, extensions are usually flimsy and won't keep a dog safely.
    This is the way I'd do it, to have a secure, solid attractive fence:
    The one side is connected to the neighbor's fence. How is his fence? solid? Is that fence 6' tall too? I really prefer to have a post here.
    If you have a gate: The other side needs a PT 4x4x8 post with 2' in concrete in the ground and 6' above grade to support the fence (make sure it's rated for ground contact). If you don't have a gate, and you connect this side to the house, you can use a 2x4 bolted into studs instead.
    Run 3 leveled horizontal 2x4x10 members (top, middle and bottom) from the post to the other side.
    Fasten your fence boards/pickets to these horizontal 2x4s. Each board/picket should have enough fasteners to secure it in place.
    Apr 2008
    Kansas City area
    48
    Smile Re: Fencepost extension
    It's hard to describe the fence w/o photos, dernit. Her fence is 8ft high, solid at that point - she recently had a gate installed so our fences join perpendicular at her gate/corner. Hers hooks to her house. If you look at it from above it looks like a stairstep from house-house. My fence is bolted into a 6' post at the house. The rails are ok so I just removed all the pickets and reattached closer for privacy, added a top rail & the top boards to match the bottom section. I removed the old rotten gate, I'm building a double-gate (2x wide as the old) so I installed a 8' post 2' deep to attach -like you said -it's secure w/concrete now. Yes it's treated (I know what a headache rotted lumber is!) Then I'll add the new top rail & boards on that side to match. So back to the "?": in order to make the fence fit the frame, I should remove the corner post and concrete and start from scratch? UGH. Not meaning to seem lazy, just didn't know how secure a post extension really is. I'm glad I didn't go buy more parts.. I'm ready to buck up and get at it at 6 a.m.! (whatwith this heat) It's already taken me 4 days. The dogs are only 33 pounds - their bark is worse.. LOL thanks for help!
    6,403
    It looks like you're on your way.
    Are the dogs 33 lbs each or 33 lbs all together?
    Apr 2008
    Kansas City area
    48
    Abby is 31 pounds, English Setter/Sheltie mix and Sasha is 33 pounds, hound/Sheltie mix - mamma was a Sheltie. They are little Houdinis so fixing this fence was a must since I live on a busy street. Thanx for your advice! I've got a 5:30 a.m. appointment with that dern fence, goodnite all!
