    9
    Question Cracked Firebox Brick
    When we moved into our 1930's era home, the fireplace had some cracked/broken bricks in the back of the firebox. I used a high heat fireplace mortar and filled in the cracks, then gave it a skim coat to make the area flush with the undamaged portion. We've used it a few times after that, and have enjoyed it. Aside from the questionable "aestetics" of having a patched area, next to the bricks, is there anything wrong "safety-wise" with my approach?
    Thanks,
    Tim
    Sep 2012
    Default Re: Cracked Firebox Brick
    i think you are perfectly safe for the moment. and procedure you have followed is correct. but if you are a little concerned please check it every once in a while if the cracks re appear
    Ditto. There's not much else you can do.
