    Jul 2012
    Default Options for Flooring on Sloping floor
    I am currently restoring a 120 year old farmhouse and have hit an issue in the living room. We have currently replaced almost the entire foundation and sills that the house sits upon (Balloon Framing), correcting a lot of unevenness with jacking. However, when remodeling the living room we found that there is a permanent set to one of the joists where it drops approximately an inch in the front of the house over 6 feet along one wall and slowly goes down that far over 12 feet from the back of the house. The stair well sits upon this joist and we have reinforced with an extra pier under the center of the stairs but it seems the far corner of the house that slopes down to this joist is sitting high.
    Due to the fact that jacking and dropping one whole side of the house is out of the question, are their any ideas as to flooring options other than carpet over this slope. I do not mind it in any way except for the fact that almost every flooring option I look into says that it cannot handle this much slope. I have also looking into the self leveling floor and such but it would be over original hardwood and asphalt tiles that were put down years ago and I am not sure how the house would respond to the extra weight.
    Any help would be greatly appreciated.
    May 2012
    134
    Default Re: Options for Flooring on Sloping floor
    I would think that "sistering" the joints with 2x6 boards after taking up the floor to the joists is the only choice.
    Jul 2012
    Cannot do that as it would raise one side of a stairwell an inch out of level due to the fact that it is built directly on top of this joist and the other side of the room actually slopes upward, out of level with the rest of the house. This is old settling from the weight of the stairs. I just wanted to know what flooring options could be placed on top of the floor now. The issues in damage have all been fixed, it is just the way the house has set and I am fine with it.
