    Jun 2012
    81
    Default back to back 90's or 45's to get down deeper
    ok so my ground work plumbing has been istalled, inspection tomorow. i nedd to get the main sewer line deeper. it leaves the addition with proper coverage but then at 3' out the existing grade changes and doesnt leave enough coverage on the pipe so i want to get it deeper. currently the pipe passes thru the foundation and then 2' out has a clean out then a piece is just stubbed out 3' (plumbing inspection only does 5' past building)
    my question is= is it better to use long sweep 90's for a vertical drop or is it better to use 45's for this? i am concerned the 45's would allow the liquid to leave the solids since it would be greater then 1/4" per foot....
    South*East
    1,257
    Default Re: back to back 90's or 45's to get down deeper
    Use 45's. There is far less chance of a stoppage with 45's as compared to 90's.
    John
    Jun 2012
    81
    excelent advise- i was worried even with long sweep 90's it would be too dramatic on flow, i will advise him to use the 45's with a short section of pipe in between. thanks.
    Feb 2012
    92
    Yeh 45's is the best route to go.
    Ben Franklin Plumbing Salt Lake City
    372 D St
    Salt Lake City, UT 84103
    (801) 416-3522
