    Apr 2009
    24
    Question prevent condensation of refrigerator cooling line?
    I had my refrigerator pulled out today to clean behind it (trying to track down the source of all the little fruit flies we have been having recently, actually), and I noticed a small copper hose, which I assume to be a coolant hose, with frost forming on it. Over the next several minutes as the fridge cycled, frost alternately formed and melted on this hose, causing it to drip on the floor. Obviously any source of un-contained water is a bad thing, especially when behind the fridge or the like where you can't get to it, so I was wondering what, if anything I can do to keep this hose from dripping? As far as I can tell it is just condensate, not leaking or the like. Thanks.
    Aug 2012
    Anaheim, CA
    13
    Default Re: prevent condensation of refrigerator cooling line?
    Your problem must have been resolved by now. Please let us know what was the problem and what had to be done to fix the problem?
    Apr 2009
    24
    Quote Originally Posted by stellawinslet View Post
    Actually, no, the problem was never truly resolved. What I ended up doing was wrapping a rag around the problematic hose and zip-tying it in place. Works well enough, I suppose
    Dec 2013
    Montreal Canada
    205
    Go to a store that sells stuff to refrigeration mechanics and buy some flexible black refrigeration grade insulation. Called armaflex. then install it over the pipe.
