Results 1 to 10 of 12
    59
    Default Need help with my push mower
    Hello, everyone.
    I have a Murray push mower and it has a pretty easy-to-remove air filter assembly. The only trouble is that I can no longer tighten the air filter housing bolt. It appears the threads have been stripped. This means that when the mower runs, the vibration causes the air filter housing to come loose.
    There are some pictures below. Does anyone know how to fix this?
    Thanks!
    Erik
    This is the housing, as it's supposed to sit on the mower:
    This is the bolt:
    And this is a top-down look at what the bolt screws into. I can't tell if it's screwing into plastic or if there is are metal threads beneath the plastic:
    7,357
    Default Re: Need help with my push mower
    If the long screw is stripped, just get a replacement screw.
    If the place where the screw goes into (inside the caburator) is stripped, you need to replace the carburator.
    You may have luck finding parts (new and used) at lawnmower repair shops. But don't shed a tear if you don't find what you need. Jusr replace the mower, it looks like you are ready for that.
    7,600
    Check the threads on the filter screw, are they rounded, worn excessively, or otherwise not it perfect shape? If so, replace it. If they are, then the hole in the bottom of the carb is probably stripped.
    It may be possible to have the hole rethreaded, helicoiled, or drilled out and tapped a little larger, you'll have to check into it and decide if the cost is worth the value of the mower or if mower replacement is the better route.
    Tennessee
    1,908
    You can get a helicoil set and renew the threads in the carburetor, then get a new screw. A cheaper alternative is to get a pierce of all thread the same size as the screw, cut to length, screw into the carb with some epoxy or JB Weld to hold it there permanently and use a wing nut on top.
    7,600
    Great minds think alike Keith.
    59
    Thanks, everyone. The all thread idea sounds like the best. I think I'll give that a shot!
    59
    If I use All Thread and secure it in the carburetor with epoxy, wouldn't it then be really difficult to remove the carburetor in the future, if I need to clean or replace it?
    7,600
    I don't believe I've seen any lawnmower small engine application where the air filter stud would pose a problem for removing the carb from the engine itself. If you're worried about it, investigate it beforehand.
    The filter stud is likely sticking straight up and down, while the carb bolts are horizontal. Once the filter pack is off and out of the way, you should have perfect access to the carb bolts.
    Tennessee
    1,908
    I don't think it will be a problem either, but instead of epoxy, there is a product called "Locktite" thread locker. It comes in three strengths, I would suggest that you use at least the medium strength, but if you are not real comfortable with that, you could use the soft strength, but it might not hold well enough. Of course, if it doesn't, you can always clean it up and go stronger.
    59
    Default Problem solved!
    I decided to take my mower to my favorite lawnmower service shop and learned the reason the filter cover no longer screwed into the carburetor was that a bunch of dirt snuck into the carburetor and caked the threads, meaning I was trying to tighten the bolt into dirt!
    It's all cleaned up and working perfectly now!
