Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. #11
    Jan 2011
    Columbiana, Alabama
    831
    Default Re: Installing A Thermal Overload
    Spruce, a good place will be between the motor and the switch.
    I agree, they're usually located in the equipment or the JB mounted on the equipment i.e. garbage disposer, saw, grinder etc.
  2. #12
    7,864
    The easiest location was before the switch, as it just shortened the power cord slightly. All that is left is to install the spade connectors and fire it up.
