Results 1 to 8 of 8
    Jul 2012
    Default framing on floating floors
    Is it ok to frames walls on floating floor? It would save a lot of cutting to put my floor down first. Thanks Ed
    Sep 2009
    florida
    598
    Default Re: framing on floating floors
    Its not advisable.....
    Gizmo
    Hidden Content
    Hidden Content
    7,559
    The risks are: unstable walls, out of plumb walls, crooked walls due to poor anchoring, besides the fact that doing such shoddy construction is not to code.
    Now you know, and it's up to you what to do.
    Sep 2009
    florida
    598
    I dont know of any code violations with doing it. I would worry more about expansion contraction movement....the floor could buckle if your anchors penetrate into the subfloor
    Gizmo
    Hidden Content
    Hidden Content
    7,559
    Gizmo, all the inspectors who I've met wanted to see how the walls were attached to the floor. In CA they inspect these things.
    7,783
    What they said, besides the fact of potential damage to the floor to be framing and working over it.
    Floating floors are about the easiest thing to install, cutting isn't a problem. Just build out the rooms as you wish, finish them completely and then the last thing you should do is install the flooring.
    Jul 2012
    15
    and be sure to leave the correct gap between the walls and the flooring, the gap will be covered up by the baseboard anyways. you just don't want the floor to buckle, your friends will laugh at you every time they see a hump. hehe
    to clarify, do not build your wall on the floating floor... build wall first then install floor. if floor is already down and your adding a wall, just outline where you want the wall with blue tape. set depth of sidewinder to the thickness of floor boards maybe a lil shy, give the right gap and cut. install upper and bottom plates studs n rock. bang on some kickers paint and your done!
    Jun 2009
    NY
    35
    As long as the sleepers below are at least 16" OC should be
    ok for interior non load bearing partition.
    http://westchester-architects.com
