Results 1 to 9 of 9
Thread: Roofing help
    Jun 2008
    Burlington, Ontario, Canada
    Unhappy Roofing help
    I will not pretend to to know anything about roofing so please bear with me.
    I noticed one of the gutters was loose so went up to check it out. After lifting up the shingles a little I noticed a gap between the plywood and the edge of the roof. The gap is large enough that I can stick my hand straight into the attic. There are also some mouse droppings at the opening.
    Looking around the roof in some places there is a metal edge (drip edge?) that comes down off the roof and to the gutters. Other places it's just the shingles that are covering this opening.
    I'm getting conflicting answers as to whether this is an issue.
    Any help would be appreciated.
    I do have a picture but can't link it as I don't have enough posts yet.
    Cheers
    David Lucas
    6,767
    Default Re: Roofing help
    1. A small gap between the plywood and the edge is acceptable, but a large gap like yours, is not.
    2. Technically, drip edge is necessary on those sides where the water drains, but most roofers will install drip edge all around the roof. Yet, I've seen many roofs with no drip edge at all.
    Building inspectors are not as tough on roof finishes as they are on other things, like framing, electrical or plumbing. At least this is my experience. But that desn't mean you can accept a poor roofing job for your money.
    Jun 2008
    dj1,
    Thanks for the reply. Sadly or maybe not it wasn't a job I had done. We purchased the house three months ago and I just noticed this now. Do you or anyone have any suggestions on a fix? I had one quote to add drip edge around the roof but didn't really feel comfortable with the roofer.
    Cheers
    David Lucas
    6,767
    A quick fix is advised. If the gap is 3" or 4" wide, install a strip of plywood under the shingles/felt paper, then a drip edge.
    Don't like this roofer? call others for bids.
    Generally speaking, you must have a good understanding with your contractor. You want a contractor who does everything to code. Never pay off a contract until everything is completed and approved.
    Jun 2008
    Thanks dj1. That was a big help.
    Cheers
    David Lucas
    Jul 2012
    10
    Jun 2008
    PAt,
    Not sure what you're trying to say.
    Cheers
    David Lucas
    Jun 2009
    NY
    35
    Smile Re: Roofing help
    nice to have ice shield at the eaves also
    http://westchester-architects.com
    Jun 2008
    designseeker,
    There is ice and water around the roof. We also just got a quote that we are very happy with to add drip edge and repair the gaps. Thanks all for your help.
    Cheers
    David Lucas
