    Jul 2012
    Talking stripped hex screw on door handle
    Hello,
    wondering if anyone can help. i was trying to tighten the door handle but used an electric drill and stripped the hex screw. The screw is located in a hard to reach place (between the handle and the door itself). Door knob is still loose and i feel like it's unsafe (it's the entrance door). Thanks in advance for any help you can offer.
    5,796
    Default Re: stripped hex screw on door handle
    You might try an easy out and replace the screw, you can get them from most hardware and big box stores.
    6,498
    If the door handle is loose, that means you can slip a hacksaw blade in between the screw head and the escutheon, and cut the screw. Once the handle is off, use a pair of pliers to get the rest of the screw out.
    237
    Since a hex screw is mentioned, I think the poster may be talking about a locking screw that keeps a handle on, although if I am incorrect, the fix would still work in either case. If the screw is stripped, you may be able to use a small drill bit to drill through whats left of the screw. If this works, you might be able to find a similar thread screw from a hardware store but it may be tricky.
    If you're not comfortable with that the only other option may be to use a hacksaw to cut off the handle as mentioned and replace it with a new one.
