    Jul 2012
    Default T111 siding/Tyvek
    Installing replacement wood siding and trim. Do I install Tyvek(vapor barrier) all the way down behind the bottom trim as well as the siding?
    Don
    7,152
    Default Re: T111 siding/Tyvek
    House wrap goes from the roof sheathing all the way down to the sill plate.
    6,694
    Check your local codes for the required house wrap in your area. The building department has that info, including application.
    Jun 2009
    NY
    35
    cover the walls and floors above the foundation, behind trim around windows?...yes
    http://westchester-architects.com
