Threaded View
    612
    Default Pondless Waterfall & Stream Project
    We have been kicking around how to incorporate a water feature in our landscaping. After a couple years of looking, planning and stalling we started our pondless waterfall and stream a couple weeks ago.
    The waterfall is two tiered and about 24" tall, the stream is about 40' long and ends at a basin that is about 5' x 8' x 3' deep (~500gal). The basin is filled with crates to take up space and create a rock free space to hold the water supply. The crates are then covered with rocks.
    A pump sends the water from the basin up to the falls via 2" pvc that is regulated via a ball valve at the falls. There is also a midstream waterfall "t"'ed off the supply to ease the pressure on the pump from turning down the ball valve at the upper falls. The midstream falls also has a ball valve to regulate flow.
    We chose 1-3 Gray River Rock for the stream & basin area, it took about 2 tons to adequately cover. We collected the larger rocks from our property, probably will use about 2 ton of those as well. We will also use about 2 ton of smaller rock over weed block as ground cover & pathway in the areas around the stream bed.
    I included a link to a photo album rather than try to upload the pics.
    http://forum.aquascapeinc.com/album.php?albumid=58
    It is not finished yet, maybe another two weeks of working on it depending on how much the real hot weather delays things.
