    Central New Jersey
    10
    Question Proper putty for ABS trim
    I am fixing up a large tool shed in my backyard. I added some trim using 1x4 PVC plastic attached with 6 penny galvenized finish nails. This is the first time I have used plastic trim, and my question is, after I set the nails, what sort of putty should I use to fill the holes? Will Plastic Wood brand filler work, or is there something to use with the plastic?
    Last edited by Fireflite; 07-15-2012 at 03:42 PM. Reason: correction: it is PVC not ABS plastic
    Default Re: Proper putty for ABS trim
    There is putty for outdoor purposes, sold at HD too. Or you can use just a dab of exterior caulking.
    1,950
    The common pre-mixed vinyl spackling compound is rated "interior/exterior". It will work fine.
