    Jul 2012
    Default Moving a vanity in a 2nd floor bathroom
    The place I'd like to move it is across the room. The floor joists run at a 90 degree angle from the way the pipe would run, Ie the pipe crosses the joists. How do I run the pipe ? Do I cut a notch in the joists and then reinforce them ?
    6,598
    Default Re: Moving a vanity in a 2nd floor bathroom
    Notching joists is permitted, subject to exclusions specified in your local codes.
    Go to your local building dept for the details, so you dont err and compromise the integrity of your joists.
    South*East
    1,213
    Depending on the size of the joists you can drill them, but it must be in the middle third of the joist.
    John
    6,598
    Quote Originally Posted by johnjh2o View Post
    John
    Let me correct what John said, it should read:
    "Depending on the size of the joists you can drill them, EXCEPT in the middle third of the joist".
    Still, where you can drill and notch, it has to follow your local code.
    South*East
    1,213
    I think were both right . Your talking about the middle third of the span. I'm talking about the middle third of the joist it self. Notches are not allowed in any location.
    John
