    Jul 2012
    Default I can't get handle off of single handle kitchen faucet
    Hi everyone,
    I have a leaky sprout on a Delta single handle kitchen faucet. I removed the screw (I believe it's called an allen screw) to remove the facuet handle but it won't come off. I don't want to tug on it because I might mess something up but am I missing something?
    Thanks for your help,
    Michael
    7,358
    Default Re: I can't get handle off of single handle kitchen faucet
    You might have some corrosion holding the handle down. The screw that you just removed is a retaining screw. Using a small hammer (don't use a sledge hammer), tap at the base of the handle, then jiggle it a little bit. It should come off.
    Of course, at anytime that you feel you can't do it, just call a local plumber for help.
    Jul 2012
    Thanks dj1. I tapped the base of the handle with my screw driver and it loosened it where I could pull it off. I appreciate your advice
    I replaced all the parts with new ones and the only thing that seems off is that it's really tight in there. I can feel some resistance when I use the handle but I don't know if that's normal because it was bad before I fixed it. Maybe it's the rubber seats that might be too big. I'm not sure but at least it isn't dripping.
    Michael
    South*East
    1,242
    Quote Originally Posted by michaelgnocchi View Post
    Michael
    Inside the cap nut that holds the ball and cap washer in place there is a tension nut that may have to be loosened. There should be a tool that that comes with the repair kit for that.
    John
