Results 1 to 7 of 7
    Jul 2012
    North Carolina
    12
    Default Open joints in inside corner
    When you have coped the best inside corner joint you can and have compensated for out of whack walls to the best of your ability, what is the best way of filling the gap? Caulk or putty? How large of a gap is too large?
    1,583
    Default Re: Open joints in inside corner
    bfelker,
    Definitely not putty. Putty is an oil based product that will get brittle with age and break out. Also not wood fillers, for the same reason. They are brittle and will break out of the gap.
    A good acrylic based caulk will have better adhesion and have the ability to expand and contract with seasonal changes in the wood molding.
    If the gap is so large that you have to ask the question how big is too big, you should probably re-cope the corner. If carpentry were perfect, fillers wouldn't be neccessary.
    6,480
    I'll have you know, I NEVER use fillers.
    bfelker, ordjen gives you good advice. Gaps "should" be an 1/8" or less, more than that will set you up for failure no matter what you used to fill/cover the joint.
    What I find helpful in situations like yours is to cut test pieces until I get the fit I want, then I move to the actual trim piece and work on that. This way you already know the exact angle you need to achieve a good quality cut. Notice I didn't say "perfect", yes, you want the joint to be as tight as possible its whole length, sometimes that's just not possible for a variety of reasons. That is why caulk was invented.
    I also like to be generous with the caulking, not to make a mess of things, but to squish a goodly amount behind the joint to "key" the caulking into the joint so that it will hold better. The face, of course, gets troweled to match the profile of the trim and give you that "perfect" look.
    Achieving a good caulk line is more about practice and technique than anything else. Start by trimming the nozzle at 30* - 45* and no larger than about a 1/8" opening. Hold the nozzle tightly into the joint so that as you apply the caulk, it is force into the joint. Here is the tricky part, you have to move the nozzle along the joint as a sufficient speed with sufficient pressure on the trigger to apply just the amount needed and NOT be blowing caulking out around the nozzle. The less you have to clean up after application, the better the end result will be. Also, have a wet rag on hand for clean-up. Wet your finger and make short strokes to remove the excess, the more excess, the shorter the stroke you make, wiping your finger clean each time. Once the excess is removed, you then go back with a freshly wet finger and make a single swipe along the joint for a smooth finish. An alternative would be to use a putty knife to remove the excess, though using a tool is a bit tougher.
    975
    There was no filler in this cherry trim project, except finish nail holes.
    It can be done, provided it's an unlimited budget!
    Casey
    5,081
    Quote Originally Posted by Sombreuil_mongrel View Post
    Casey
    The sky is the limit when it comes to budgets. Nice work, even though I see too much red.
    6,480
    That was my thinking as well, looks like some sort of sacrifice has taken place in this room!
    Jul 2012
    North Carolina
    12
    Thanks for the advice. With a little patience and some mild profanity, I got all joints closed pretty tightly. Will caulk soon.
