    Jun 2012
    Default Remove concrete deck anchors
    Hi all,
    I just removed part of our upper deck, including two 20-ft support posts. Each post was attached to a heavy-duty metal bracket embedded in a concrete footing. So now I have two big concrete footings sticking out of the ground. How can I remove them? They're big (18x18x12) and heavy.
    Thanks!
    Default Re: Remove concrete deck anchors
    Unused concrete footing/anchor can be removed. Knock it with a sledge hammer or a jack hammer, just below grade, and cover with dirt.
    Sep 2009
    florida
    598
    If the footings only 12" deep then dig it out then bust it up
    Gizmo
    Hidden Content
    Hidden Content
    Apr 2012
    26
    I did the same thing, I used a sludge hammer till below grade and covered them
